Results 1 to 10 of 89
Thread: Brand new pool owner = new to BBB method
    Default Re: Brand new pool owner = new to BBB method
    Quote Originally Posted by stslimited84 View Post
    Also, to clarify, while reading through the forum ive read 2 gallons of 6% bleach will raise my FC levels by 5ppm correct? Based on that and the best guess chart, the shock level is 12-15 ppm which equates to 6 gallons of 6% bleach. Sound about right? how soon after adding the bleach should i test for the FC level?
    I was frustrated and panicking earlier today, didnt want to end up with a swamp, and have been using all available resources. I sincerely appreciate the help Ive been receiving. Thank you very much
    No, but close! Good for a newbie! 2 gallons of 6% will add 4ppm of chlorine to your 30,000 gallon pool, not 5ppm. ! gallon of 6% add 6ppm to 10,000 gallons, therefore 1/3 that to 30,000 gallons or 2ppm. 2 gallons therefore adds 4ppm.
    Aim for a shock level of 15ppm. 7 Gallons of 6% bleach should do it. Current FC: 1ppm. 7gal adds 14ppm, which equals 15ppm.
    Just my "take"
    Jul 2011
    Just my "take"
    my mistake, i forgot to edit my first post. I took measurements and believe my pool is 25,000 gals...so 6.5 gals should get it there? Do I need to adjust the CYA level since the chlorine seems to be getting used fast or leave it where it is? How soon after adding the shock dosage should I test? and am i correct for shocking due to not knowing how the previous pool owner left the water condition?
    Your dose of 6.5 gallons is right. While you are fighting this, as often as you can test and add more bleach the better. There is no such thing as doing it too often. Every time you test, add enough bleach to get back to 15. You could stand to bump the CYA up a little if your reading of 30 is right. Maybe add another 2 lbs. of CYA. Put it in an old sock and hang it in front of a return jet. Give it a squeeze every once in awhile to help it dissolve faster. That should add another 10ppm of CYA for you. You want to continue shocking until you can go from sundown one day until sunup the next day without losing more than 1ppm of chlorine.
    It's a lot to learn at first but you're doing great!
    Jul 2011
    I believe I have this sorted out for the most part now. Seems as tho I was making quite a newbie mistake. The vacuum w/the same debris catcher bag has been in the pool since we bought the house a week ago. After adding the shock dosage earlier this afternoon, I realized this probably shouldn't be in there especially with that bag full of debris.
    Well lo and behold, I turned off the pump then disconnected and removed the vacuum from the pool. I finally saw a current in the water! Tested the water after about 20 mins and got a reading between 12-15ppm! Well after feeling some relief and needing to eat, I got lunch and returned to walmart to buy more bleach.
    Returned home, tested the water at about 345 pm, and got a FC reading of 3 ppm. Progress! Since I dont have internet at the house yet, I used calculations previously printed the from poolcalculator.com based on raising the 3 ppm to 12 ppm. It called for 3 gals 3 quarts. I added it, tested the level at 410 pm, and got a reading of 15 ppm, woohoo!
    Im going to test the pool water tonight when its getting dark and make the necessary adjustments. Couple of questions for you guys and gals:
    1) For clarity purposes, based on a pool size of approx. 25000 gals, 1 gallon of 6% bleach will raise it by how many ppm?
    2) I tested my Ph a couple times today and got readings of 7.0. I believe I need to raise this to 7.5-7.6. The above listed calculator states I should add 11 lb of borax by weight. Is that accurate?
    3) I'll test for the CYA and post the results. Would this be a good price for it? http://www.lowes.com/pd_86401-1772-0...ine&facetInfo=
    4) Getting ahead of myself (hopefully only slightly), once the pool reaches the point where it loses 1ppm or less overnight, what are the next steps?
    1. Approximately 2.5ppm
    2. Never add 11 lb. of anything at once. You may either overshoot your target or end up with cloudy water. Add a box of Borax and wait several hours. Then retest pH and redose if needed. Anywhere between 7.2-7.8 is ok. Once your pH starts to move, you might want to go to smaller doses than full boxes at a time. Do NOT test pH when your chlorine is high, however, or you will get a falsely high pH reading. Test pH before adding a new dose of bleach.
    3. I don't know. I haven't bought any CYA lately.
    4. When you can pass the overnight test, I'd keep the chlorine high for one additional day for added insurance and then let the cl drift down and maintain it between 3-6ppm all the time.
    Jul 2011
    just got back from testing the pool at sundown. FC was at 1 ppm. TC was at 3. Ph was at 7. CH was 230 ppm. Ta was 90 ppm. The CYA was something less than 30 but i couldnt tell b/c the tube was full and i could still see the dot although cloudy. The chlorine tests are approximate (and consequently less accurate) bc the colors are hard to distinguish sometimes (see further down in post)
    i added 3 gal 3 quarts as i did earlier to bring it back up and then tested the water a little bit later and got an approximate reading of 10 ppm. Again Im not sure b/c the colors are hard to distinguish and I had to use the dilute method b/c the reading was above 5 ppm.
    Im going to add the CYA tomorrow as you suggested.
    I edited out the borax comment bc i just saw your earlier reply. 10-4 on the borax instructions.
    I also ordered the Taylor K-2006 kit as suggested on here and am going to return the one I got at leslie's...its too freakin' hard to read the color adjustments for chlorine, especially at shock levels or anything above 5 ppm. Unfortunately the kit wont be here until next week
    how we doin' so far? what ya got for me?
    Check the post above yours. I just replied one minute before you posted again. Good decision to get the Taylor K-2006. You won't be sorry. You're doing fine! Keep us posted how things are going.
    Jul 2011
    Thank you so very much for the help! I will most certainly be donating to this site.
    Can the CYA and borax be added at the same time (seems as tho they can be).
    I have another dilemma which I need help with. So within the past week Ive had a ton of stuff going on. Closed on a new home. Been doing some renovation to it. Reading, learning, and applying new info to maintain a pool for the first time On top of all this, Im going on vacation on friday and will be unable to provide the pool with my undivided attention as I am now. At this point, I'm not sure the pool will be out of the shocking stage by early friday morning. That being said, how can I get through the next week without coming back to a swamp. I will not be home but I have family who will be watching the house and pool. They have never had a pool and have no knowledge about pool maintenance.
    What would be the best course of action? put several (if so, how many) 3" trichlor pucks in a floater and leave the pump on all week?
    Its been a whirlwind of excitement and activity with all this going on and im trying to keep my head from spinning off, lol
    Jul 2011
    Boca Raton, FL
    The only question I can throw my two cents towards is this one: 3) I'll test for the CYA and post the results. Would this be a good price for it? http://www.lowes.com/pd_86401-1772-0...ine&facetInfo=
    I bought 4lbs of stablizer (not 3lbs) at a local pool store for the same price ($13.83 for my nearest Lowes). Maybe check your local pool supply store for a better price.
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
