Results 1 to 10 of 89
Thread: Brand new pool owner = new to BBB method
    Jul 2011
    Default Re: Brand new pool owner = new to BBB method
    Had an aggrevating problem develop today. Some piping from the outlet of the pentair multiport (50181212) cracked and now there is a steady leak. While shutting down the filter to remove the piping I omitted closing the multiport and some of the D.E. went out into the pool through the skimmer, drains and return piping. I emailed pictures to poolforum AT gmail DOT com of the broken piping if a moderator could add them that would be great.
    1) I realize I need to vacuum the D.E. from the pool, but will this mess up my water chemistry or is it okay in there for a day or two until I can get the proper vacuum head and tubing?
    2) Can I replace that specific piece of piping including the cracked nut, or does the entire multiport have to be replaced? (pool service guy said the whole multiport has to be replaced)
    3) How much hose do you think I should purchase for the vacuum?
    4) Anything else I'm missing or need to do?
    25,000 gallon Concrete/Plaster Pool with a D.E. Filter. K-2006 Test kit. Pool Forum Rocks!
    Jul 2011
    Quote Originally Posted by stslimited84 View Post
    I ordered 40' of vacuum hose and this vacuum head - (LINK REMOVED BY MODERATOR so your post could be modded in quicker)
    I'm currently still trying to find out if I can get just those parts for the multiport, and if I can, how quickly I can get them b/c the leak needs to be fixed asap. The multiport for the D.E. filter I have is priced between 125 and 150ish online.
    But back to the main question, is the D.E. that went back into the pool going to cause problems with my chlorine and other parameters or is it ok to swim in the pool?
    Honesdale PA
    If the multiport valve body itself is not cracked then it doesn't need to be replaced. If the valve body is trashed then you have nothing to lose by trying to fix it. If the body is cracked at the threads I'd try JB Weld. Home depot, Lowes etc. I'd get a new PVC male fitting and smear it with the JB and thread it in and let it set. If the body is cracked beyond the threads then try the JB from the inside. the stuff is tough. As I said....nothing to lose. We're trying to see if we can see the pics you sent. I'm not sure how to do that yet. Maybe Ben is the only one who has access.
    Jul 2011
    any luck on viewing the pics?
    Try sending them to poolforum DOT pics AT gmail DOT com instead and we'll get them posted. Ben is pretty busy right now and I'm sure he just hasn't gotten to it.
    Don't forget to reference the URL of this thread so we can get them to the right place.
    Jul 2011
    Pics sent
    Jul 2011
    Quote Originally Posted by Poconos View Post
    Some success was had. The new nut which replaced the cracked nut corrected part of the leak; however it was not the main leak. The main leak is coming from the filter where the gasket meets the metal of the filter. It is old and not very pliable anymore. Going to try a few things today, and if need be, go the jb weld route which I think/hope will fix it if we get to that point.
    I'm thinking next year I'm just going to get a new D.E. filter, with a step up in size. The pool plumbing supply store charged 9 dollars for that plastic nut, ridiculous! Do newer filters come plumbed with standard PVC pieces/threading?
    As far as the pool's daily chlorine fluctuations, at night I've been bumping it up to about 5.5 ppm. When tested the next evening, its at 2.5 ppm, so it almost holds at the minimum level but not quite. Should I bump up the CYA?
    I would try bumping up the chlorine level first and see what effect that has. 7-ish, maybe? If that doesn't work, and the consumption is purely sun and not junk in the water, then it won't hurt to bump it up a little. But use small increments-- you don't want more CYA than you need!
    Jul 2011
    Hey guys,
    just an update. The pool seems to be holding chlorine levels better now...im thinking the cya has fully dissolved. Its holding throughout the day and I'm adding about 1.25 gals of bleach daily. Seem about right or is it using too much chlorine?
    Also, the Ph levels seem to keep rising. Last week the ph was about 7.8, so I lowered it with muriatic acid to about 7.2. Tested it again today and its back up to 7.8. It shouldnt rise this fast should it?
