Results 1 to 10 of 89
Thread: Brand new pool owner = new to BBB method
    BigDave's Avatar
    Default Re: Brand new pool owner = new to BBB method
    I think you've got some extra digits somewhere. 237 lbs sounds w-a-y high.
    One of the reasons I'm not in love with the pool calculator is that it tends to encourage people toward a 'fix it in one dose' approach to chemistry. This was a BAD idea, when pool stores pioneered that approach, and it's a BAD idea now.
    There IS an exception: low chlorine should be fixed in one dose, and usually, more is better. (More as in 3x too much, not 50x too much!)
    For everything else, it's much, much better --- in PRACTICE --- to dose, test, and re-dose if needed. For your 25-30,000 gallon pool, you are around 1/5 of a million pounds of water. So, if you add 1 lb of CYA, your CYA level will increase by 4 - 5 ppm. Calcium chloride dihydrate ends up being about 60% 'active' with respect to CH test results, so 1 # of Calc chloride will add 2 - 3 ppm calcium hardness.
    So, if you wanted to increase your CH by 60 ppm, you'd need to add 20+ lbs of calcium chloride. But DO NOT DO THIS! As mentioned above, it's a generally bad idea. But, in a pool with a chemistry approaching calcium carbonate saturation, ANY large addition of pH+, alkalinity+ or calcium+ will tend to precipitate a cloud of calcium carbonate.
    What's the solution? If you need to take a pool to saturation -- and you probably don't -- SMALL repeated doses are a much, MUCH better way to do it. So, instead of adding 20+ lbs, add 5 -10 lbs and then retest.
    Jul 2011
    Yeah you're right, I had an extra zero on the calculator. I knew that figure was not correct, good catch.
    Thanks for the replies. So Doc, let me ask you. How do I know what the saturation level is for the pool and at what level to stop? I want to make sure I get the calcium level where it so its all set when it comes time to close the pool in a month or so, b/c if ive read correctly, having a calcium level to low in a plaster pool can cause damage to the pool due to the water drawing calcium from the plaster.
    I 100% agree with your slow dose and retest method. Have been using it since I started BBB.
    25,000 gallon Concrete/Plaster Pool with a D.E. Filter. K-2006 Test kit. Pool Forum Rocks!
    Jul 2011
    Just to verify, would the best way to add the calcium be via the sock method?
    also, sadly it will be time to close the pool in a few weeks...I will be having a pool company take care of the closing in regards to the equipment (blowing out the lines, cleaning the filter, etc), but Ill be handling the chemical aspect.
    What do I need to do to close the pool chemically?
    Thank you kindly
    Jul 2011
    i was able to locate some peladow as suggested. How should I add it to the pool? sock method or add via the skimmer into the filter?
    Jul 2011
    Quote Originally Posted by stslimited84 View Post
    anybody?
    bueler? bueler?
    Peladow is just calcium chloride, right?
    Assuming a "Yes", I'd recommend broadcasting it in 1/3 doses. Adding large amounts in one place (or through the skimmer) can cloud the pool from local formation of over-saturated water.
    Alternatively, you can add it via the skimmer in even smaller divided doses.
    Jul 2011
    My apologies, i realize this is in the wrong forum, but i figured I'd keep it all in the same thread.
    As I mentioned, I'm having the pool closed by a professional this year so I can observe what is done; however I'm going to take care of the chemical aspect so I know what goes into the pool. I have plenty of bleach but have not purchased polyquat yet bc I'm waiting for the say so from you fine folks first.
    Thank again for all of your help this pool season.
