I typically run the pump about an hour after I add bleach but on this small pool, probably half an hour should be fine.
here are my reading (TH) 100 (FC)3/6 (PH) 6/8 (TA) 80 (CYA) 0
Could not find any 20 Mule Team Borax look at Home Depot, Walmart so I purchased a container from walmart with Stabilizer-Conditioner..written on it. HTH I know you said not to but that was all they had
Have only used Bleach as you said.
Look at the ingredient list on the Stabilizer-Conditioner you bought from WalMart. If the active ingredient is just cyanuric or isocyanuric acid, then that's what Watermom wanted you to get. If there is any other active ingredient, list it here before you put it into your pool.
Active ingredients is Cyanuric Acid 96% Inert ingredients 4% That is all that is on it. Balance
That's the stuff.
Go ahead and put it in the sock and hang it in front of your return like Watermom instructed in her above post, so you can start getting some CYA in your water as soon as possible.
How much do I use?
