Results 1 to 10 of 13
Thread: Low Cya and it won't go up
    Default Re: Low Cya and it won't go up
    If you take a 2 gallon bucket of pool water, then every 1/4 teaspoon of 6% bleach is 10 ppm FC and you can see how much it takes before the chlorine starts to hold. If you had CYA loss over the winter from bacterial conversion of it to ammonia, then for every 10 ppm CYA it can take 24-30 ppm FC so if you lost 50 ppm CYA then that's up to 150 ppm FC to clear it. Hopefully, you're close to the end, but a bucket test wil be a faster way to find out.
    You could also get an inexpensive ammonia test kit from a fish/pet/aquarium store but you might have gone through much of the ammonia by now. Do you measure Combined Chlorine (CC) even though your Free Chlorine (FC) goes to 0 after some hours?
    My CC has been staying between 1 and 3 since May
    So this does sound like you had a major conversion of CYA into ammonia and the chlorine you are adding is creating and partially destroying CC. If you look at the post I linked to earlier for the timeline of when this happened to me, you'll see that there was CC and a huge chlorine demand. The bucket test is your easiest way to determine how much more chlorine you will need. An ammonia test might also be useful, though you might not measure that much now given how much chlorine you've added.
    I wouldn't add more CYA until you are able to keep the FC from disappearing so fast. With no CYA, FC should drop in half in about an hour but you shouldn't be losing much overnight. Right now your loss rate is much faster than that so you are still getting rid of ammonia, monochloramine, and partially oxidized CYA. Unless the FC is able to stay above zero, then bacteria can still survive and consume the CYA you are adding -- you're giving them a nice meal!
    You can see that prevention is far easier than having to deal with this. Making sure the chlorine level never gets to zero (certainly for no more than a few hours) is key. Closing a pool as late as possible so that the water is cold and shocking with chlorine and then opening as early as possible in spring with the water is still cold will help prevent this from happening again.
    Have you tried:
    1) getting fresh CYA reagent
    2) having your water tested somewhere to see what they get for CYA?
    Even with high ammonia levels in the water new CYA should register on testing.
    Also, Is this an inground or above ground pool?
    How often do you need to top it off with new water?
    Do you have an autofill on the pool?
    Have you tried:
    I did buy another container of fresh CYA.
    I did not have the water tested elsewhere, I do now have three test kits that I used and tested other pools using them and they all worked fine so I ruled ot test issues.
    Above ground pool 24'X52"
    I have not added much water this year. It was just about full at the start and I haven't needed to add much this year. The weather has been good so we haven't had much evaporation so far, much less then other years.
    No auto fill.
    I closed it right before it went down to freezing and opened it as soon as we had no more freezing. The bad thing was it would go to 80 degrees one day and drop to 0 for a few days. When I opened my pool it looked like a swamp. After adding chlorine I had frogs popping out like corks. I do what you said and hope for the best.
