Thread: Repairing Old Concrete Coping
    Jul 2011
    Washington State
    Default Repairing Old Concrete Coping
    Our in ground pool was installed July 1960. Several of the concrete coping stones are broken and we'd like to replace them or install new coping. Anyone know of a source?
    I have a couple of photos but will need to figure out how to add them.
    24' x 40' In ground Concrete with plaster. 44,000 gallons
    Default Re: Concrete Coping
    This poster's photos unfortunately got buried last summer, and were never posted.
    But, I'm doing so now as part of a cleanup process, because they are good examples of old cast concrete coping. I've dealt with these many times locally, and always found the problem to be that they were locally cast, using local molds, that were no longer available. This leaves four options that I know of, when they need to be repaired or replaced:
    1. Use a high strength concrete patch to 'glue' them back together, when they break. I've done this with cement and Acryl-60 latex.
    2. Pay the local company to make NEW molds and recast the coping. This is very expensive, so I've never followed through.
    3. Find locally available coping that matches as closely as possible. I've wasted a lot of time on this, and ended up with coping that didn't match all that well.
    4. Remove all the coping, and pour a new cantilever edge.
    Jun 2011
    In the Sticks near Houston, TX
    Thanks for the post. That looks real similar to mine built in the 80's and I always wondered what I would do if/when I need to repair some. They do have some battle scars through the years but are in overall good shape.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    Patch 'em before they break!
  1. cleaning coping and concrete around pool and sealing it
    By wishIcould in forum In-Ground Pool Construction and Repair
    Last Post: 05-29-2013, 10:19 AM
  2. how to mix white concrete. Other coping advice welcome!
    By sunkissed in forum In-Ground Pool Construction and Repair
    Last Post: 07-06-2012, 08:46 PM
  3. Advice on Concrete coping needed.
    By DJK555 in forum In-Ground Pool Construction and Repair
    Last Post: 05-28-2012, 05:05 PM
  4. where to get concrete coping form
    By bcrumb in forum In-Ground Pool Construction and Repair
    Last Post: 05-22-2011, 03:05 PM
  5. Concrete coping vs. rim lock coping
    By Sean-NJ in forum In-Ground Pool Construction and Repair
    Last Post: 08-18-2006, 04:00 PM
