Thanks for the update. If you are going to use the trichlor pucks, you'll need to keep an eye on your CYA as the pucks will continue to add CYA. Every week or two, test it and when it gets to about 50, you'll need to discontinue using them. They are also very acidic, so you'll also need to watch your pH to make sure it doesn't get too low.
