Results 11 to 18 of 18
Thread: Clear water, everything else wrong?
    Jul 2011
    Default Re: Clear water, everything else wrong?
    FC: 5
    pH: 6.8
    TA: 60
    CYA: 100
    So... my guess is add washing soda which will raise pH and also slightly raise TA?
    19,000 gallons, vinyl, 250 sq ft cartridge filter, automatic cover, 1 hp pump, heater
    You can do that, but if your TA rises faster than your pH, you may end up needing to switch to Borax after awhile. Kind of depends on how low your pH actually is. Since the pH tester only goes to 6.8, it could really be much lower than that.
    #9 - Once you've added the polyquat, resume raising the pH until you reach a level of 7.4 - 7.6. At that point, your heater will no longer be 'under atttack'.
    => Use borax, till you've sustained a reasonable pH for a couple of days.
    Jul 2011
    Opened filter for first time in a week. It is covered in aqua "stuff". Consistency of wet paint, completely covered. Linking pictures because I'm not sure you'd believe me otherwise.
    (pics removed by moderator)
    Ummm... help?
  6. #16
    Laguna,
    please email the pics to poolforum AT gmail DOT com and include a link to this thread so that we can add the pics.
    Jul 2011
    Sent, thank you!
  8. #18
    Here are your pictures. They are almost certainly showing some form of copper, possibly copper carbonate -- but I've never seen filters look like that before. I did a little checking, and am wondering if it's copper borate -- the color is awfully blue for copper carbonate,but seems right for copper borate:
    http://www.youtube.com/watch?v=ZOIeJQwkH (couldn't find any stills)
  1. water never clear
    By Tressa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-08-2012, 03:28 PM
  2. can't get the water clear
    By mumptia in forum Dealing with Algae & Slime
    Last Post: 08-21-2006, 02:51 AM
  3. Oh My!!! Water Is Clear!!
    By Jaybird70 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 08-09-2006, 07:48 PM
  4. Algae gone-water still not clear
    By karenkr in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-22-2006, 11:44 AM
  5. Can't clear cloudy water
    By ScrltOTara in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-02-2006, 08:44 PM
