Results 1 to 10 of 51
Thread: Using a Nature 2 system with the BBB method
    Default Re: Using a Nature 2 system with the BBB method
    Just FYI; often bad sand means you've been using things the pool store sold you that you would have been better off leaving in the pool store!
    Jul 2011
    Chattanooga, TN
    yes, in my case, 17 years of junk sold by the the pool company. I know better now. I'll let you know how the filtering goes now that the filter is working correctly.
    1994 Sun Pools Fiberglass in ground 20,000 gallon pool - Nature 2 purifying system
    Wood stove heater - Stainless steel liner - Hayward 3/4 hp impeller super pump and S-244T 62GPM sand filter
    Good luck!
    Jul 2011
    Chattanooga, TN
    Overnight has made a big improvement! I suspect it will take several days of filtering, vacuuming, brushing, etc., but real progress is being made!
    Great!
    Jul 2011
    Chattanooga, TN
    BTW. I checked with the pool store, and the parts guy said that the impeller that I have a 3/4 hp impeller on a Hayward super pump.
    Yes, but is it a 3/4 UP-rate or 3/4 FULL-rate impeller?
    Never mind -- I think you've found and fixed your problem. If it's working, it's working, and don't mess with it, unless you just like to tinker!
