Re: Hayward EC50AC pumping green back in pool???
Since last post, I've run the filter for 24 hrs on the first day, then 10 hours per day after. So far I still see green shooting back into the pool, but a lot than before. The pressure went up from 10 to about 15 after the first 8- 12hrs of running the filter, and I've had to bump the filter at least 3 times since first putting in the 9 - 13oz coffee cans of D.E. Pool is a lot clearer than before, but I am still getting some green on the bottom of the pool (again, not aas much as before). I have not used any Algecide yet, is it time I start to? I've been using chlorine tabs in floating chlorinator, and shock to clear up the algea in the pool.
It's also been very hot in the Northeast this week.
