Thread: Zodiac SWG - Do I really need Salt Saver, Salt One, etc.
    Default Re: Zodiac SWG - Do I really need Salt Saver, Salt One, etc.
    Do you need to add them? In a word, no. If you want to know why they are being recommended it's because the more chemicals the store can sell you the more money they make.
    The basic chemicals usually needed for a salt pool are salt (and you don't need expensive pool salt either--ordinary water softener pellets or solar salt works just fine), muriatic acid, stabilizer, and perhaps calcium for a plaster pool. Borates, while not needed, are highly desirable but they can be added inexpensively with plain ordinary borax and some muriatic acid.
    Jun 2011
    If this is a Zodiac Duoclear (or if you have the Nature2 system by itself), save yourself the $100 per season for the cartridge and just remove it (if it's the Duoclear, you can open up the cartridge, remove the "mineral" bag and replace the empty cartridge into the Duoclear unit - a cartridge has to be there or the thing will leak). Then run your chlorine level at the reommended level based on your CYA level (for salt water pools), instead of the ludicrous 0.6 level suggested by Zodiac.
    All I use in my pool with a Duoclear (mineral bag removed last year) is salt, and muriatic acid to lower the PH level (and bleach when I open after winter to shock the pool). Since I lowered my TA to 70-80, the PH rise slowed markedly. After I added borates, the PH seems to be locked at 7.6.
    Jul 2011
    Thanks folks,
    the system I have is the one with the cartridge that needs to be replaced each year (although I decided to reuse last year's cartridge this year because we opened the pool just in July).
    rcy100: how long do you expect the electrodes to last?
    I've been trying to find a good source for Taylor kit in Canada. The prices seem to be much higher than in the US but I haven't found a seller shipping to Canada yet.
    Thanks again for the suggestions, I'm seriously consider getting a membership on this forum.
    Cheers
