Thread: chlorine
    Jun 2011
    Wisconsin
    Smile Re: chlorine
    I am using regular chlorox bleach. I added 3 gallons Thursday night, 1 gallon Friday night, and 2 gallons Saturday. When i got my test kit on Wed., my free chlorine was at 1.5, so it has come up considerably since then. Is there a reason it needs to be as high as 15 before I bring it back down? I'm assuming it's to make sure its sanitized, but how long should I do these large doses? When should I bring it down?
    Thanks for your help
    16'x32' oval 20K gal AG pool; Liquid Bleach; Hayward pro series, 18 inch sand filter; Hayward Pro series 1.5 hp pump; 15 - 20hrs; Taylor, k2006; well; summer: ; winter: ; android phone; PF:6
    Default Re: chlorine
    You've been trying to get it up to shock level in order to burn off the CCs. If you can test the chlorine tonight, and test again in the morning before the sun is on the pool, and not lose any chlorine in the meantime, then you can let it fall to normal chlorine levels, which for a CYA of 80 means 5-10 ppm.
    Apr 2011
    virginia
    what aylad said...
    1 gal bleach in 20k gallon pool only adds 3 ppm FC, so you've added 15ppm. some of that was used converting CC, and some lost to sun, so 11.5 is about right.
    If CC <1 and FC holds, you don't need to shock
    Jun 2011
    Wisconsin
    Thanks for the help!
