Results 1 to 10 of 14
Thread: Lime Green Pool Water
    mbar's Avatar
    Ashland, PA
    Default Re: Lime Green Pool Water
    Just another thought - before I learned what I now know about stains, I also had lime green water. It turned out that my white fiberglass pool was stained yellow all over. Blue plus yellow equals green! When I got rid of the stains the water turned blue. You can see if the pool is stained by lowering the level of the water and see if there is yellow on the part you can see.
    Northeast PA
    Good point, Marie!
    Pool surface colors can affect apparent water color a LOT.
    PS: Marie, if you see this, check your email!
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Lime Green Water now -- Metals?
    By bcdavenp in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-01-2012, 01:44 AM
  3. New Pool ... green water
    By btokash in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-26-2012, 03:43 PM
  4. Lowering phosphates with hydrogenated lime
    By czechtranslation in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-14-2012, 05:18 PM
  5. Help, Pool looks like lime koolaid
    By woman.n.a.shoe in forum Dealing with Algae & Slime
    Last Post: 06-25-2006, 10:29 PM
