Results 1 to 10 of 14
Thread: Lime Green Pool Water
    Default Re: Lime Green Pool Water
    Amy,
    I'm going to let Ben continue to advise you. I am only going to add that it is usually best to either follow the advice given to you here on the forum or that given by a pool store. When you do some of 'ours' and some of 'theirs' it doesn't usually work too well.
    Amy,
    You're going to need to get a K2006 or K2006C for me to continue helping you . . . AND you're going to have to stay out of that pool store. They are not only selling you products you don't need, they are giving you bogus test results: there are NO dealer test systems that would allow them to distinguish Alk=151 from Alk=160, much less from Alk=155. Those systems usually are based on electronic readers of 'goofy strips' -- but the strips themselves can't reliably measure Alk well, much less CYA.
    Meanwhile, run your pump / filter 24/7 and add small doses of bleach to maintain your chlorine levels.
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Lime Green Water now -- Metals?
    By bcdavenp in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-01-2012, 01:44 AM
  3. New Pool ... green water
    By btokash in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-26-2012, 03:43 PM
  4. Lowering phosphates with hydrogenated lime
    By czechtranslation in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-14-2012, 05:18 PM
  5. Help, Pool looks like lime koolaid
    By woman.n.a.shoe in forum Dealing with Algae & Slime
    Last Post: 06-25-2006, 10:29 PM
