I tested my pool water with the OTO kit I have when I got home from work. The chlorine level is somewhere in the 1.0-1.5 ppm range, which is where it usually is unless it has recently rained. The ph is a little lower than my kit says is ideal, but only by a little. I would say it is around 7.5. The kit says ideal is 7.6. It is hard for me to match up the colors exactly which is why I was already contemplating buying one of the Taylor kits before Watermom suggested it to me in the previous post. The chlorine and ph levels are pretty consistent. It doesn't matter if I test in the morning or in the evening like I did tonight. I don't seem to be losing much chlorine. I only run my SWCG for 2 hours per day. Any more than that and my chlorine readings get up around 5 ppm.
I double checked the tank on my toilet. The "brown" I referred to earlier is a brown ring around the top, at the normal water level, not the entire inside of the tank (if this makes a difference).
I also got in the pool tonight and investigated the brown "gunk" a little. The walls of the pool are NOT slimy at all. I have read that this is an indicator of algae in other threads. The brown stuff looks kind of like dirt, but when you try to pick it up with your fingers, it disintegrates. It is slimy almost like the slimy mud in the bottom of a river. I don't have a lot of it. It is just in small isolated spots on the bottom of the pool about the size of quarters. I tried vacuuming it up, but I have the cheap vacuum that came with the pool. (the kind that connects to the garden hose and then catches debris in a little net) After tonight, I am sure that once the "gunk" is disturbed, it just washes right through the holes in the net.
Any help is appreciated. Thanks in advance.
