Results 1 to 10 of 24
Thread: Halfdones's pool
    Default Re: Buying new filter system, need advice
    Just add the CYA separately and switch to bleach. Since you are fighting algae and will most likely be backwashing frequently, I wouldn't put the CYA into the skimmer but instead put it in an old sock and hang it in front of a return jet. Give the sock a squeeze every now and then to help it dissolve faster. Since you've been using dichlor for a but, I'd aim a little low for the CYA to account for the amount that is already in the water but just not measurable yet. Probably aiming for about a 30ppm dose (4 lbs). would be good. Then, after a week, test CYA and see where you are. You can then decide whether you need to add more or not. Quit using dichlor shock or trichlor pucks. Just use bleach.
    To clear the algae, try and keep the chlorine at 15ppm. In an 18K gallon pool, each gallon (4 quarts) of 6% bleach will add about 3.3ppm of cl. Test as many times per day as you can (no such thing as too often) and each time, add enough bleach to get back to 15. Run the pump 24/7 and backwash any time the pressure rises 5-10psi over clean filter pressure. Continue to sustain the high cl until you can go from sundown one evening until within 2 hours of sunup the next morning without losing more than 1ppm of cl and your CC is no greater than 0.5. At that point, I'd suggest running the high cl levels for one additional day for added insurance and then let the cl drift down and keep it in the proper range based on your CYA. (See the Best Guess Table in my signature below.)
    Have you added the DE yet? If not, I'd wait until the algae is dead and you aren't having to backwash so frequently as backwashing throws the DE out.
    With the K-2006 kit, always use the 10ml sample instead of the 25ml sample to conserve your reagents. The 0.5 accuracy is sufficient.
    One last request. To make it easier for us to help you, we are encouraging people to create a signature line with the specs of their pool set up in it. You can do this by clicking on settings in the upper right hand corner of the homepage. We would like you to put the following things in there: type of pool, volume, type of filter, size of pump, and the fact that you have a K-2006. That will help us to be able to answer posts more quickly especially when threads get long. It is time-consuming to have to continually scroll back through a thread to look for basic information. Thanks.
    Jul 2011
    Great idea about the signature, done.
    I am following your instructions. The algae is fairly dead I think unless there is some still alive on the bottom. The pool is blue but very cloudy. Since the filter is fairly stable at clean-out pressure I went ahead and added a cup of DE to the filter. I did a fresh backwash before adding the DE even though I was only 1psi over nominal. The pressure went up about 4-5psi within about 2 minutes of adding the DE. I did dissolve it in a bucket of water but perhaps I should have added it slower so I could stop at 1psi over nominal. The normal starting pressure is about 15psi so I backwash at 25psi. I will watch it closely and backwash if it gets to 25psi. When adding DE to the sand filter do I use the original starting pressure after the fresh backwash or use the new "DE" pressure as my starting point. Next time I'll add less DE so I only increase about 1psi.
    I added 4lb of CYA in a sock and hung it in front of the return line. After about 4 hours its almost gone. Isn't that a bit fast? I expected it to slowly dissolve over several days. I have been checking the FC levels and am still at 8 after about 4 hours since I added Bleach. I should have been at around 15 after my last dose 4 hours ago. I'll re-dose to get back to 15 for the night.
    Pool Specs: Vinyl IG 18,000g, Hayward 270 sand filter 350# standard filter sand (15psi after backwash), 1hp single speed Jacuzzi pump, Taylor K-2006 test kit.
    You only want a 1psi increase when the DE is added. Backwash it out and try again. Add a smaller amount. You may not see the pressure rise immediately. It always takes 20-30 minutes to show up in my pool. Pre-dissolving it is right.
    It is fast for CYA to dissolve, but even still, I wouldn't test for it for a few days.
    Jul 2011
    I backwashed the DE out and reapplied. This time I used about 1/2 cup predisolved and it went up about 1-2lbs. I'll leave it there and keep an eye on it. I see what you mean about it taking 20-30 min for the full increase. I'll figure it out sooner or later how much to apply, then it should be easy after that.
    I'll wait for another couple of days for the CYA test but already our Chlorine seams to be lasting a bit longer.
    Any ideas on the cloudy water problem. We have tried clarifiers in the past but it didn't do a thing. It almost looks like white smoke in the pool. I can barely make out my second step. I think the particles are so small they pass right through the filter. I am hoping the DE trick will help but would like to get it done quicker. I have been running the filter constantly for 4.5 days now.
    On the Chlorine test when checking the CC level do I multiply the CC test with the result from the FC test or do I multiply by the value (1 drop = .5ppm) that I used for the FC test? Does that make sense?
    Thanks again, its nice to finally start seeing progress.
    On the CC test, multiply each drop by 0.5ppm.
    Resist the temptation to add a bunch of stuff right now. Just bleach. Give your filter a chance to do its job.
    BigDave's Avatar
    Your CYA may have come right through the sock without being dissolved in which case it is probably sitting on the pool floor but you can't see it through the opaqe pool water. As I understand it, CYA has a very low pH and may damage your liner if it sits on it. I'd brush the bottom as often as possible until you can confirm it is granule free.
