Re: Buying new filter system, need advice
I am running the pump 24/7 only taking breaks to backwash if needed and about 10-15 minutes to let the sand settle after the backwash. last night at about 10pm the FC was 14.5, this morning at 11am it was 7. I am testing and adjusting as often as I can and trying to keep it around 15. The flow rate seems fairly good the pool water is flowing around in a circle like a river current, much better rate then my old DE filter. At this rate if I keep the FC at 15 and the pump running constantly how long should it take to clear up the pool?
Thanks,
Pool Specs: Vinyl IG 18,000g, Hayward 270 sand filter 350# standard filter sand (15psi after backwash), 1hp single speed Jacuzzi pump, Taylor K-2006 test kit.
