Results 1 to 10 of 13
Thread: how much acid
    Jul 2011
    Wantagh
    Default Re: how much acid
    The acid is pure sulfuric acid brand new never opened. And my ph is high.Thanks
    As long as it's pure sulfuric, it's OK. Not as good as hydrochloric, at least for concrete pools, but one dose won't cause problems even there. Use small doses, however. I have no idea what the strength is, compared to standard muriatic.
    Jul 2011
    Wantagh
    Got back from walmart a few hours ago picked up the hth 6 way test kit(it was the best one they had) and the last 7lb bottle of hth ph minus. My chlorine and ph are high(off the scale) the TA was around 150 and it only turned the blue to a pale red on the test kit so maybe a little higher. On the total hardness test the water didn't turn red but did go to blue after 10 drops so i guess 100ppm and the CYA was 90ppm. Just did a vacum to waste and a long backwash to dump some water(couple hundred gallons), should i add the ph minus or keep dumping water? Thanks for your time and help
    I guess I'm going to throw the question back to you: it depends on whether you want to run a high CYA pool or not.
    Read the Best Guess page linked in my signature. If you keep the high CYA, you'll have to run the chlorine levels shown. It scares some people to run FC that high, though there are no ill effects on outdoor pools that we've been able to discover. And you tend to use less chlorine, and certainly don't have to dose as often with a high CYA / high Cl pool.
    Personally, I'd run high CYA, high Cl, rather than dumping all the water. But it's up to you. The 'classic' BBB method I developed assumes lower CYA levels.
    You'll either have to run the chlorine levels shown OR lower your CYA. If you want lower the CYA, you'll need to replace 1/2 of your pool water. If you do drain, do so safely. Inground vinyl pools can't be drained without professional help; inground concrete pools in low or wet areas can 'float' out of the ground, destroying the pool. AG pools shouldn't usually be drained completely -- but 6 - 12" of water left is usually safe.
    Jul 2011
    Wantagh
    Thanks for your help, been adding acid and PH is starting to drop now with my TA at 150 should i aerate my pool? If yes i have a few questions,the idea is to turn your returns up so they make white water correct? I also use my submersible pump( for my cover), with that pump should the discharge hose be just above the surface making white water like the pool returns or hang the discharge off my kids tree house and make a big splash? Also can i introduce air? I can weight down(deeper is better?) a garden soaker hose hook it up to my compressor and make a 50' bubbler. Or would bigger bubbles be better? I can hook up my bounce house blower to a piece of shop vac hose and blow bigger bubbles just fewer. I don't if any of this is a good idea or not but if the extra pump is make sure you tie it down (i use my ladder) or it will spin like a top and break the wires, itself and maybe the liner. Thanks again for your time and help
    The more aeration -- white water -- the faster the TA will drop IF the pH is also low (<7.2). The more violent the aeration, the faster it will drop.
    I've stripped 100% of the TA from a heated spa in 10 minutes, using the blower. Of course, you can't duplicate that in a pool.
    Ben
    Jul 2011
    Wantagh
    I should drop the TA correct? What about making a bubbler? Thanks
    Sorry i forgot my PH is still high
