Results 1 to 10 of 13
Thread: how much acid
    Jul 2011
    Wantagh
    Default Re: how much acid
    sorry for not getting back to you sooner but its been real hot in ny so i could only do a little work at night. I have bad asthma so i stay in the ac as much as i can in the day and since my pc is in my basement i didnt want to risk the stairs to reply. Anyway here is where im at i think, using the hth 6way kit(by the way is this kit any good?) TC=15/25(kit only does total CL not FC) PH=7.2/7.5 TA=80 I guess my CYA is around 70/75 i changed a little water since my last reading of 75 but not enough to make a big change. How important is hardness in a outdoor inground vinyl liner pool? when i try that test it takes 8 drops instead of 5 to turn the sample red and 7 drops of the titrant to turn blue. now according to the pool store(they use the strips and scan in into thier computer) shock treatment=1.7 TC=9.8 FC=8.1 PH=7 TA=40 CYA=30 and TH=90 and thier advice is to drain more water. the water dosen't look much diffrent then it did a week or so ago its still cloudy with a green tinge when i brush or vac to waste is see no algae the water looks pretty clean you can almost see the bottom in the shallow end. I added clairifier a few times last week and nothing i can see happened. I think im getting close, but the pool store said water change and no CL for a while what do you think i should do? Last question im not sure if my pump is working 100% it seems to be not pumping as hard(90/95%) i have no bubbles i blew out my intakes and returns checked my impeller which turns easy but squeaks(rubber o ring?) changed the sand in my filter and replaced all gaskets/o rings in my multiport valve the psi guage still needs replacing but i believe it works enough to see a 10lb increase it just seems a slight bit clogged/blocked somewhere. THANK YOU FOR YOUR HELP
  1. Where to buy CYA? & acid ?
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 01:13 AM
  2. Dry acid vs Muratic acid
    By jackinlv in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-25-2011, 01:44 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. Too much acid?
    By k2vell in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2006, 10:57 PM
  5. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
