Thread: Stabilizer?
    Jun 2011
    Default Stabilizer?
    Hello everyone. I am a newbie to this pool thing. We have an AG pool with a SWG. It is very hot right now where we live and it seems the SWG is not keeping up with th free clorine. I have up my output as I have read that the hotter the weather the more you have to up the output. The levels are better now. My real question is should I be using a stabilzer to help hold the chlorine level?
    May 2010
    Default Re: Stabilizer?
    Absolutely, You need Stabilizer. Here is a bit of a testimonial. Being a real card carrying "Big Tall Dumb Guy" with a SWCG, my scatter brain told me I didn't really care too much about the CYA (stabilizer) levels. So when I replaced my pool liner last year and installed a SWCG, I added some CYA but not enough. My Chlorine levels were good with my CYA at 25 - 30 PPM, AND ALL SEEMED GOOD.
    After all, my chlorine is FREE, Right? Wrong! Chlorine isn't "free" when you have to run your pump twice as long to keep the Chlorine levels up (NOT TO MENTION BURNING OUT YOUR CELL).
    I had to run my system for 7 hours a day to keep from running out of chlorine at sunset. I decided to stop being so stupid and I raised my CYA to 45 ppm and I am now running my pump for 4 hours a day. The $10.00 bottle of stabilizer will save me hundreds (Plural) yes hundreds of dollars in electricity.
    You can learn a lot from a BIGTALLDUMBGUY!
  1. Is stabilizer necessary?
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2012, 07:48 PM
  2. Stabilizer
    By cooper in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2011, 10:26 PM
  3. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  4. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  5. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
