Results 1 to 10 of 13
Thread: New pool owner here
    Jul 2011
    Muskego, WI
    Default Re: New pool owner here
    Well thanks for responding. I thought I was on the do not reply list for a second there. Haha. Well thanks to all the info I read on this site my pool is up and running perfectly. Couldn't be happier with the BBB method. I have been real busy building my deck around the pool. Pretty soon I will actually be able to enjoy the pool. What I thought was iron on the bottom ofthe pool actually turned out to be mostly sand so that was a pretty easy fix. The one question I still have is that my TA is pretty high. Its hovering @200. Im wondering if I should be worried about it or not. I read on here somewhere not to lower it just to get to a number. The water is perfectly clear and everything else is where it is supposed to be. I know how to lower it if I need to, I'm just wonderig if I need to. Thanks in advance
    24' round AGP@13,800 gallons
    Hayward 1 1/2hp pump -Sand Filter - Vinyl Liner
    BBB Method
    Hi andy, and welcome back!!
    Glad the pool is up and running, hope you're getting a chance to enjoy it. As far as the TA goes, if the TA of your fill water is 200, and your pool isn't having any problems (i.e. your pH is stable), I wouldn't bother to lower it, because it'll be an endless fight-- every time you have to top off with fresh water, you'll be raising the TA again. However, if your fill water is lower in TA, then it wouldn't hurt to go ahead and drop it some.
    Jul 2011
    Muskego, WI
    So I guess the next step would be to test the water coming out of my hose to see what the TA levels are. If they are high there's not much I can do, but if it's low I might as well lower the TA of my pool. My PH did go up .3 in one day but that was after a heavy rain. Not sure if that matters or not. What would be a normal ppm per day/week change in PH in the perfect world? Thanks
    BBB Method
    Yes, test the TA of your fill water. As far as what would be normal change in pH in a day ---- pH, for the most part, should be pretty stable if your TA is adjusted appropriately. (Unless you have a new plaster pool or a SWCG, both of which will see pH rise.)
    Just to add to what Watermom said, if you had a really heavy rain, that could have aerated the water enough to bring the pH up a little bit. The TA in my pool is 110, and my pH rarely moves from 7.8, unless I do something (like add acid) to move it. In most cases, though, it's right back to 7.8 within a day or two, because that's the pH of my fill water. I tried to fight it for the first couple of years, but then I realized I was just wasting time and acid!
    Jul 2011
    Muskego, WI
    So I finally checked the TA of my fill water and it is over 300. Knowing that, is it worth trying to lower the TA or leave it where it is? It is still hovering @200. My PH does fluctuate somewhat, so will that cause any problems? Thanks
    BBB Method
    Jul 2011
    Muskego, WI
    I checked the PH yesterday afternoon-7.4. At 10:30 today its 7.5. So not that much change today. I guess I will have to check it daily and see how much change there is. Actually since I filled the pool originally about 3 weeks ago I havent added any water, but its getting to the point where in a few days I will have to if it doesnt rain. I am still in the process of adding CYA at this piont and I am almost there, so could that be contributing to my problem of high TA? Also I was wandering around on the internet and stumbled across this filter contraption that would go on the end of the hose for my fill water, and supposedly it would filter out metals in the water. Has anyone ever tried one of these? or know of anyone that did? and if so what were the results. I would be happy to shell out the $40 or so to get one if it works, but I am a little bit skeptical. Thanks
    BBB Method
