Thread: Vacuuming an Intex pool
    Jul 2011
    Milwaukee WI
    Default Vacuuming an Intex pool
    I just bought a intex sand filter Model SF15110 for my intex 18x48 easy set pool with the metal poles. I was wondering how I vacuum the pool. I have the skimmer that hangs on the side of the pool. Where? How? do I hook up the vacuum. Do I vacuum the pool as I did, when OI had the cartridge filter system that came with the pool? Thanks for the help.
    Default Re: Sand filter
    I've seen pics of that skimmer. You'd have to disconnect the skimmer from its drain hose and hook the vacuum to it. Or you can get a garden-hose vacuum that blows the dirt into a catch-bag. There are a few out there--I know Biogard still makes one--I saw it Saturday. Black Magic also makes one....they are similar in concept to the hose-driven leaf-vacuums.
    When I had my Intex I had to creatively invent a way to hook a suction vacuum to the filter. I used a 3/4" double-female Schedule 40 adapter as the go-between. I clamped it into an 18' length of 1.25" corrogated pool hose, attached the hose to the vacuum, and plugged the Schedule 40 into the drain. The sizes were right and it worked nicely. Not the strongest vacuum but the filter caught stuff the catch-bag couldnt.
  1. Water Tech Blaster Pool Max Reviewed
    By MattW in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-10-2016, 05:45 PM
  2. Trouble vacuuming the above ground pool
    By cawo1965 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-19-2013, 10:21 PM
  3. Problems vacuuming pool
    By texasdontholdem in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-05-2011, 04:36 PM
  4. vacuuming sand in pool...
    By resp215 in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-05-2011, 04:27 PM
  5. Backwashing/Vacuuming--water coming back into pool
    By lolynn633 in forum Pool Equipment & Operations
    Last Post: 06-07-2010, 11:52 AM
