Thread: sand...constant sand
    Jul 2011
    Default sand...constant sand
    I have a small above ground pool with an intex cartridge filter. I net daily, keep my chemicals up and change the filter cartridges regularly. My pool is sparkling clean, except for the sand. My pump/filter does not have enough suction, so I use one of those you hook to a waterhose. I put a pair of pantyhose over the net bag to help, but even though I spend several hours once a week vacuuming....letting everything settle and vacuuming again....more sand is always there. Its not mustard algae..it is not slim....my and moves real easily...any ideas?
    Thanks,
    Aymztx
    Default Re: sand...constant sand
    The only solution I know of is some sort of pool vacuum.
    I don't understand how you can vacuum it, and not get rid of it. Does it keep coming back? Is it actually "SAND" or is it something else?
    Lehigh Valley, PA
    What does the ground around the pool look like? Lawn? Or sandy? Could it be the kids bringing it in on their feet? If so, you can set up a plastic bin or a tiny baby pool and have them rinse their feet before getting in the pool.
    Largo, Florida
    Quote Originally Posted by AnnaK View Post
    One of my neighbors uses the baby pool method. They have the end of the ladder that goes on the outside of the main pool right in the baby pool for catching dirt/grass/mud/bugs/whatever would get tracked in. I would imagine it has to be dumped pretty regularly, but the baby pool instead of a little tub ensures that no kids can skip cleaning their feet.
  1. replaced sand and now sand is entering pool
    By flomenhoft in forum Pool Equipment & Operations
    Last Post: 07-21-2012, 01:29 PM
  2. Sand Filter dumped all the sand in my pool
    By ib_gman in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-15-2012, 01:16 AM
  3. Sand Filter Sand amount question
    By kevincad in forum Above-Ground Pool Construction & Repair
    Last Post: 07-04-2008, 09:36 AM
  4. Sand Filter Pressure Problems; Sand Bad in 3 MONTHS of USE?
  5. Jacuzzi ST-24 sand filter - sand in pool
    By ksturge in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 09:58 AM
