Results 1 to 8 of 8
Thread: pits and red algae
    Jul 2011
    bloomfield hills, mi
    Default pits and red algae
    My gunite pool has pits in the plaster averaging 1" in dia. now in these pits I find what appears to be red algae. Have never seen this before. The water is sparkling clear. Regular additions of algacide and a correct chlorine level don't seem to help. shock doesn't help. the red can be scrubbed off with a wire brush, but keeps coming back. Any ideas?
    I'm new here, have lurked for a year or two, but this is really the first problem I've had with the pool since I moved in 3 years ago.
    thanks in advance,
    Chris
    Default Re: pits and red algae
    Can you send pictures to poolforum AT gmail DOT com? That would help.
    Is the red stuff attached, or like loose dirt or powder? Algae would be attached.
    Does putting chlorine powder or a chlorine tab ON one of the spots bleach it out? If it's algae, it will after an hour.
    Jul 2011
    good thought on the chlorine tab to bleach it out. I will try to take some photos this weekend. I was not brought into the problem until it was a big mess. Lots of algaecide has been used, enough to kill the chlorine, which in turn was shocked to bring that up, which lowered the pH to a frighting level. All is in balance now, and still plenty of algaecide in the water.
    I was told the pits/craters came for a long time ago using the wrong algaecide, copper based I think. In my last 3 years with the pool, nothing like this has happened. Guess I'm due, eh?
    Copper doesn't cause pits. Stains, maybe. No pits.
    Low pH (acid) causes pits. So do various type of surface defects.
    Jul 2011
    These pits were there when I moved in, and that's what I was told. Didn't make sense to me either. I did put a chlorine tab on a brite red spot, and indeed overnight it bleached it out. Now that the pH is correct, and I added 20# of stabilizer, do you think a bunch of shock and chlorine tabs in the skimmers/pump basket might get rid of the red? In another thread I was told it is not algae, but a bacteria. the pool is approx 44,000 gal. Again the water is crystal clear, but the red spots are ugly. I have been informed (you know, told) to get rid of them pronto.
    Do NOT leave the chlorine pucks on the spots long; they will etch &/or discolor the surface.
    You'll need the K2006 kit in order to manage the chlorine levels you'll need to get rid of the stuff. Getting a good nylon bristle pool brush would help, too. (If you use it!)
    Did you really put 20# of stabilizer in? That's about 60ppm, if it all dissolves! If you did, turn your feeder UP, and use an cheap OTO drops chlorine test to check chlorine levels. You'll need to stay in the dark yellow range.
    When did you add the stabilizer and how did you add it? If you added it through the skimmer and it was maybe yesterday, you could backwash and get most of it out and keep that CYA level from getting too high. If it has been more than a few days, then it has probably already dissolved in the water.
  1. New pool owner - question on Diamond Brite pits
    By famousdavis in forum In-Ground Pool Construction and Repair
    Last Post: 07-28-2011, 10:25 PM
  2. Avoiding Algae / Removing Algae
    By PoolDoc in forum Dealing with Algae & Slime
    Last Post: 07-24-2011, 10:40 PM
  3. Cloudy water...then very small amount of algae...then algae bloom
    By Allan in forum Dealing with Algae & Slime
    Last Post: 07-12-2011, 10:49 PM
  4. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  5. Green algae? Mustard algae?
