Results 11 to 13 of 13
Thread: Clear Pool but cannot maintain free chlorine level?
    Jun 2011
    Default Re: Clear Pool but cannot maintain free chlorine level?
    Thanks Ted. My pool is an AG so I only have one return which could be even higher PH rise. Once I try the acid a little at a time I will look for a drop. If it does I will just have to keep it in check and if it rises with the SWCG I will bring it down again. My only question is I keep reading when I put in the Muratic Acid I have to aerate but with an AG pool how do I acheive this?
    Aerate by pointing the return jet upwards to create as much turbulence at the water surface as you can. A pool full of splashing kids will also aerate.
    SalemCastles Guest
    Hi Mr Mooks,
    I'm in Pickering ... looking forward to 38C tomorrow.
  1. I can't maintain chlorine in my IG vinyl pool
    By Nysitemgr in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-13-2013, 10:42 PM
  2. No Free Chlorine Level
    By dltodaro in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-08-2012, 06:41 PM
  3. How much chlorine per day to maintain?
    By Mm_putnam in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-06-2012, 09:59 AM
  4. Going on Vacation - how to maintain CL level?
    By herb396 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-29-2011, 12:28 AM
