I know you've set aside a heat pump as an option as a "paid energy pool heater", but I'm curious to know, why?
We turned on our heat pump for maybe two hours last evening to warm our spa to 95 degree. The heat pump was only on for a portion of that time, though, as it didn't need to run the full two hours to get the spa up to 95 and keep it there.
We enjoyed the warm spa, then turned off the heat pump. I didn't need to worry about having a warm attic or having the sun outside (we warmed our spa after dusk). The heat pump appears to use about as much energy as my home central A/C does. By running my heat pump just for two hours, it will hardly put a blip on my monthly electric bill.
Wouldn't a very low-cost, somewhat higher maintenance option be to use a solar blanket? Once the blanket is purchased, you've got the trouble of covering/uncovering your pool, but maybe it's best for a "free" pool heating option, as you don't have to run either your pool pump or air conditioner.
