Results 1 to 10 of 30
Thread: new home owner -- new pool owner -- clear as MUD
Threaded View
  1. #8
    Scottsdale, Arizona
    Default Re: new home owner -- new pool owner -- clear as MUD
    Don't backwash while adding the CYA.. You'll just flush it out .. You need to wait a week or so after adding CYA before you backwash.
    If you just put the sock in , you may want to remove it (and add more ) , backwash and then start adding CYA.
    Last edited by Watermom; 07-20-2011 at 04:29 PM. Reason: OOPS! Meant to hit edit on my post but hit it on yours instead!
