Pretty much any properly working cartridge filter will remove DEAD (not live!) algae. If yours doesn't something's wrong with either your vacuum or your filter.
You can't clump algae so you can "scoop it out with a net" -- those products don't produce clumps that size. Are you using a hand vacuum? (Pole, hose, vac head) If not, try that.
