Results 1 to 10 of 10
Thread: cloudy water
    Jul 2011
    Default cloudy water
    I have a 16 intex frame pool.the water is cloudy.if I keep the kids out of it for a day it clears up.I am using the BBB method.I'm using a cheap walmart test kit.my cl reading is 3 my ph is 7.6.I haven't gotten a good test kit yet so not sure what my cya is.I have been using chlorine pucks most of the summer and have read on here it will raise your cya.Today I took a water sample to the local pool store,guess what they said? shock it with the bags of shock...... ask them what my cya level was they said it don't really matter.so I guess time to order a good test.I vacuumed it good for the first time this summer,will see what it looks like in the morning.I think I really need a better pump and filter.
    Default Re: cloudy water
    It's quite possible for a batch of kids to overload a pool's clean up capacity.
    But that may not be happening. Check the chlorine level just after the kids leave the pool. If it's low . . . you need to raise levels so that a decent chlorine level is STILL present when they exit the pool.
    Jul 2011
    sorry just getting back on here.I went to a different pool store they said cya was at 50.they said phosphates were high and I need phosphate remover,I told him I had some at home.I know from reading here don't buy their chemicals.I will check chlorine after kids get out today.I'm guess that's whats happening.Its a 16ft pool with 4 to 6 kids in and out all day.
    Jul 2011
    yea checked it after they got out of it and chlorine was 1,from what I have read with a cya of 50 my chlorine should stay at 5,maybe thats my problem,
