Results 1 to 10 of 10
Thread: cloudy water
    Jul 2011
    Default cloudy water
    I have a 16 intex frame pool.the water is cloudy.if I keep the kids out of it for a day it clears up.I am using the BBB method.I'm using a cheap walmart test kit.my cl reading is 3 my ph is 7.6.I haven't gotten a good test kit yet so not sure what my cya is.I have been using chlorine pucks most of the summer and have read on here it will raise your cya.Today I took a water sample to the local pool store,guess what they said? shock it with the bags of shock...... ask them what my cya level was they said it don't really matter.so I guess time to order a good test.I vacuumed it good for the first time this summer,will see what it looks like in the morning.I think I really need a better pump and filter.
    Default Re: cloudy water
    It's quite possible for a batch of kids to overload a pool's clean up capacity.
    But that may not be happening. Check the chlorine level just after the kids leave the pool. If it's low . . . you need to raise levels so that a decent chlorine level is STILL present when they exit the pool.
    Jul 2011
    sorry just getting back on here.I went to a different pool store they said cya was at 50.they said phosphates were high and I need phosphate remover,I told him I had some at home.I know from reading here don't buy their chemicals.I will check chlorine after kids get out today.I'm guess that's whats happening.Its a 16ft pool with 4 to 6 kids in and out all day.
    Jul 2011
    yea checked it after they got out of it and chlorine was 1,from what I have read with a cya of 50 my chlorine should stay at 5,maybe thats my problem,
    If you've got anyone at home you can depend on, you might want to mix and store a 'mid-day' chlorine dose for them to add, say 1/4 gallon of bleach in a 1 gallon bleach jug filled the rest of the way with water. If everyone gets out of the pool while someone walks that around the edge, they could get back in 5 minutes later.
    Jul 2011
    thanks pooldoc,this has seemed to work.have been adding bleach when the kids get out.water is back clear.from what I have read here it seems my chlorine was getting to low for my cya level.plus too many kids in the pool.....
    Quote Originally Posted by MurfreesboroTn View Post
    thanks pooldoc,this has seemed to work..
    you're welcome -ben
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
