Re: Jandy SWCG's "optimal" water conditions: why raise CYA?
waterbear
Have you received the Taylor kit yet? I think you will find there is a BIG difference between 'barely adequate' and a good test kit. If I remember right your old test kit was OTO and not DPD. There is a reason that the Taylor kit is recommended, otherwise we would probably recommend getting a cheap '5-way' kit from Ace Hardware and adding a CYA test to it. The end result is so different it is a case of apples and oranges!
Not yet. I am expecting it this week. I am looking forward to working with this kit when it arrives.
Yes, barely adequate vs. good, I'm sure is miles apart. But for the record, since May, 2010, when I converted to Salt along with a new liner and fresh water, My pool has been sparkling clean, without a single algae bloom or "green" day, and no burning eyes (thanks to many people on this Forum) I only have had to add bleach one time. All with my old test kit and a few tests at the pool store. So justifying the $57 for a Taylor kit was a little rough. My last bout with the CYA levels (different Thread) was the last straw.
The residual CYA in the liner, plumbing etc. was suggested before and is the only thing that makes sense, as it would be chemically impossible to repeat the readings with 4 Lbs. of CYA. I didn't know until now if this was a real possibility or a theory. Thanks for clearing that up.
