Thread: Running a Variable Speed Pump from a Autopilot Digital SWG Controller
    Jul 2011
    Default Running a Variable Speed Pump from a Autopilot Digital SWG Controller
    Question: How to run a Variable Speed Pump from an Autopilot Digital SWG Controller.
    Somewhere I read an answer on how to do this, but I can't remember the specifics.
    I have an Autopilot Digital SWG System and just installed a VS 3050 Pentair pump (Model 011018).
    The artical I read said the Autopilot will keep the low speed circuit energized 100% of the time, except when the High Speed circuit is on, and to re-wire the Autopilot for Two-Speed Mode and connect the VS-3050 to the Low Speed circuit, which I did.
    My problem is; how do I now control the SW Cell?
    If I try to program the Autopilot, it only asks when to turn on the high speed circuit.
    If I use the High Speed mode, it shuts off the power to the VS 3050.
    Thanks,
    Default Re: Running a Variable Speed Pump from a Autopilot Digital SWG Controller
    Uhhhhhh .............. I dunno. But, somebody around probably does. If you think you read about this here on the forum, try doing a search for it. Instead of using the software search, use the search in my signature below. It is much better. Until your registration is complete, you will have to log out first to be able to see the search results, though.
    Welcome to the Pool Forum!
  1. If you run a variable-speed pump at half-speed, does the turnover rate double?
    By famousdavis in forum Pool Equipment & Operations
    Last Post: 07-25-2012, 01:22 PM
  2. what speed on a variable pump?
    By bomberchamp in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 11:53 AM
  3. variable speed pump
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 01-16-2012, 09:18 AM
  4. 2 speed pump,need new controller box?
    By bcrumb in forum Pool Equipment & Operations
    Last Post: 04-02-2011, 12:22 PM
  5. Intelliflow pump with Autopilot Digital
    By gkosin1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-10-2007, 01:58 AM
