Re: Sudden cloudiness
Since, I wasn't going to be around for 3 days due to working 14 hours per day, I decided to take the proactive approach. I've had too many times that I didn't put chemicals in for three days and came back to green ring around the bottom of my pool. And add in the 90-105 degree temps these past days, I did not want to chance the algae build up.
"if not broke don't fix it"...that approach don't work well with pools, it called upkeep not trying to catch up with an algae problem.
I'm sure once I run the chemicals thru for a while it will clear up, like it has in the past...but thanks for your colorful comments and great suggestions
