The K-2005 is a DPD test kit. The K-2006 uses the FAS-DPD test instead. Otherwise the kits are the same. You can buy just the FAS-DPD test separately as the K-1515, in its own separate box. That and the K-2005 together are the same as the K-2006, plus having the DPD test.
