Results 1 to 8 of 8
Thread: confused on cya
    Jul 2011
    Default confused on cya
    my little aqua chem test kit wont read stabilizer level at all....i can fill the tube all the way up i still see the black dot. my ph is fine tho....should i add stabilizer or what?
    Default Re: confused on cya
    Yep. You need stabilizer; 2 - 3 # per 10,000 gallons.
    The most reliable way is to put it in a sock or socks, and hang it (them) in front of a pool return. It takes several days to dissolve.
    Jul 2011
    Default
    ok but what im wondering is why add stabilizer if all that does is increase your need for chlorine? i guess im confused someone help lol
    and i did hang the sock in front of the return it was dissolved when i got home, i suppose(around 11 hours)
    If you don't have stabilizer in your pool, your chlorine is lost to the sun almost as soon as you put it in. CYA (stabilizer) is kind of like sunscreen for your chlorine. It allows it to stick around long enough to do its job of sanitizing the water.
    Stabilizer is a two-edged sword. Don't have any and your chlorine can be absorbed in as little as 15 minutes in direct sun. Put too much in and unless you keep chlorine high enough algae can still take hold.
    For most of us stabilizer levels can be anywhere between 30ppm (really the miniumum you should have) to 80 or 90ppm (usually for people with salt water chlorine generators).
    Jul 2011
    Thank you guys SOOOOO very much. with my stabilizer test (black dot) not even reading anything two days ago until i added stabilizer i am going to guess that this has been why its taken so much bleach to fend off my green water problem. I put the bleach in every night and it has taken forever but i think the water is mere hours away from from being clear. its light light light LIGHT green/blue and boy does that feel good! Once again...thanks to all of you that responded.
  1. I'm Confused
    By Lisa Tone in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-05-2011, 04:17 PM
  2. I'm confused
    By topless in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2007, 10:29 AM
  3. Confused about CYA
    By circlenranch in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2006, 08:16 AM
  4. New and Confused
    By ussnewco in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2006, 10:28 AM
  5. I'm a Little Confused ...
    By vinnygnj in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-28-2006, 09:28 PM
