Results 1 to 10 of 35
Thread: My P.O.P. is gone. need help again
    Default Re: My P.O.P. is gone. need help again
    Left covered all day with minimal sun. No pump run through night and day. First time in 3 months
    4:30
    FC 10
    FC .5
    You don't have any sort of cartridge or ozonator or extra filter or other gizmo installed, do you?
    I'll let you know what I decide about the tests you want to run.
    Uh, you might have not meant that exactly, but we don't have any particular desire to run them. It's just that -- unless there's something you've overlooked or forgotten to tell us -- there's nothing else we can do to explain your situation.
    As far as we know, chlorine in an unused swimming pool with CYA=100 does not drop like that, unless bromine / bromide or iodine is in the pool.
    Jul 2011
    Williamsport PA
    no nothing extra. You told me to let you know when i get the things needed. I just meant that I let you know if I decide to waste your time running them.
    You mean to tell me that a coverd pool with minimal sun, pump not running isnt gonna loseat least 1ppm in 11hours.
    20,000gl - 18x36 inground vinyl - Grecian Technican/Fox
    Not what I'm saying.
    Your losses the previous day were what I spoke of. The losses you are reporting now aren't consistent with those, either.
    Jul 2011
    Williamsport PA
    Sorry. I just thought that it might be normal for my pool and conditions to lose what it does after seeing that it didnt lose much with no one in it and less sun.
    It's not normal for a *stabilized* chlorine pool. It *is* normal for an unstabilized chlorine pool. And, it *is* normal for a bromine pool.
    But, odds are, it will resolve itself over time. Even bromine -- unless you used the bromine tabs, which contain hydantoin -- will eventually be converted to bromate.
    If there is no sunlight and no bather load and an FC that is roughly 10% of the CYA level, then 24-hour chlorine loss is typically under 1 ppm and sometimes under 0.5 ppm, but the exact loss depends on temperature. In my own pool at 88ºF that number is on the order of 0.7 ppm FC per day (with normal bather load and the pool cover open 1-2 hours most days and longer on weekends and 40 ppm CYA, the loss is closer to 1 ppm FC per day). For residential pools that usually have a low bather load but that don't have a pool cover and are exposed to sunlight, the usual daily chlorine loss is around 1.5 to 2.5 ppm for most pools though some may be higher if there is heavier organic load such as blown in pollen, etc. This loss rate is also a function of the CYA level where higher CYA levels (with proportionately higher FC levels) lose less chlorine.
    Jul 2011
    Williamsport PA
    all I can say is my cya is 100 and starting of with a FC of 10. Introducing a kid or kids with suntan oil and a dog and sun my pool will be down to 5ppm in several hours. Ive bought so many jugs of bleach im losing track of the money im spending. O well ill see what happens the rest of summer and hope next year is betterm thanks for th great replies
    Scott
    A dog is equivalent to many bathers and if the kids urinate in the pool then that can also create a large demand, but it sounds like this happens every day for you, not just for such one-time incidents. Are you saying that if kids and dog do not get into the pool and there is just sunlight that the FC doesn't drop or are you saying that it does? I'm trying to understand if it's specifically the introduction of the kids and dog that are causing the drop.
    Jul 2011
    Williamsport PA
    Theres been very few days that no one has been in the pool. Its been 2-3 months since I have covered it. The other day was the first time covered. It wasnt a very sunny day and no one had been in it. I think it dropped 1 or 2ppm in 11 hours. If I remember correctly it has dropped uncovered full sun with no one in it. Its yo yoing too much based on replies. Just last night it was 9ppm covered and this mourning 8. No one in it yesterday except 2 frogs. the kids get out to go pee and so does the dog. It does drop sharply when we are all swimming. I would have to put bleach in it all day to maintain 10ppm
