Re: My P.O.P. is gone. need help again
If there is no sunlight and no bather load and an FC that is roughly 10% of the CYA level, then 24-hour chlorine loss is typically under 1 ppm and sometimes under 0.5 ppm, but the exact loss depends on temperature. In my own pool at 88ºF that number is on the order of 0.7 ppm FC per day (with normal bather load and the pool cover open 1-2 hours most days and longer on weekends and 40 ppm CYA, the loss is closer to 1 ppm FC per day). For residential pools that usually have a low bather load but that don't have a pool cover and are exposed to sunlight, the usual daily chlorine loss is around 1.5 to 2.5 ppm for most pools though some may be higher if there is heavier organic load such as blown in pollen, etc. This loss rate is also a function of the CYA level where higher CYA levels (with proportionately higher FC levels) lose less chlorine.
