Results 1 to 10 of 12
Thread: bleach clouding water?
    Default Re: bleach clouding water?
    That's really strange..maybe Ben can shed some light on it?
    With those numbers? I'm guessing you have an algae bloom that keeps coming back because you let your chlorine levels get too low...FC=1, CYA=40. I think it may be dead algae that then needs to be filtered out.
    The only other thing it could be is a high metal content, but of some odd metal like magnesium, where the precipitate is whitish. It's not calcium, unless your calcium reading is wrong and it's much higher.
    mbar's Avatar
    Ashland, PA
    I just got home a little while ago and the water is almost clear. It may have been an algae bloom, but the chlorine had been steady at 4 to 5ppms for the past month and a half. I just think that it was too strange that my chlorine never did drop before that day, and to have so much cloudiness when the algae had to have just started, hey but I have heard of stranger things. Maybe it was all the dead worms! The chlorine did drop today about 3ppms, but it was hot and sunny. The metal in my water may be magnesium, because I checked my calcium in my faucet and it is not that high. What really is the question is why has my water always clouded where I put the bleach in for the last 3 seasons? I never noticed it before then, but maybe didn't pay too much attention because it does dissipate very quickly (except Saturday). That's why I always say that different pools can react differently to certain chemicals because you don't know what exactly is in the water.
    Northeast PA
    mbar's Avatar
    Ashland, PA
    I am thinking that maybe the walmart bleach has something in it that clouded my water? Did this happen to anyone else? It is labeled Great Value and is 6% bleach. My water has cleared up, but today I put in Clorox 6% bleach and it did not cloud. Hmmmm, It may have been an algae outbreak, but I just think it would not happen that fast to get that cloudy, or is this something that can happen. Anyone's input would be appreciated! Thanks.
    Northeast PA
    Marie,
    I have used Walmart's generic bleach for years and never had that happen. I'm pretty sure that is what Janet uses, too. I don't think it is because of the brand of bleach. It is 6% sodium hypochlorite and 94% water, just like Clorox.
    Yes, that's the only kind of bleach I use....but I guess it's possible that the batch that you had some sort of contaminant in it?
    No "Fresh Lemony Scent!", right?
