#1 - Get a cheap OTO / phenol red test kit that you can use yourself.
#2 - Add 3 gallons or 12L of plain 6% household bleach in the late evening; then brush the yellow areas.
#3 - Test the following evening with the OTO kit; if the chlorine level is not DARK yellow, repeat dose and brushing.
#4 - Continue this for 3 days AFTER all trace of the yellow algae disappears.
#4 - Then read the Best Guess page, and use it to determine correct chlorine levels for YOUR pool.
