Thread: Best Levels of Water Chemistry
    Default Re: Best Levels of Water Chemistry
    You want your pH to be between 7.2-7.8. We usually recommend alk to be between 80-120ish but yours is fine at 130. CYA at 85 is a little high but not a problem as long as you keep your chlorine levels where they should be based on the Best Guess chart. I wouldn't use any stabilized forms of chlorine, however, such as trichlor pucks or dichlor powder.
    I see the subscription thing got worked out.
    Jul 2011
    garden city, ks
    Thanks, Watermom !
    Yea, it appears everything worked out.
    I am going to vacuum to waste the settling silt in My pool. That should help a tiny bit with the CYA. I want to wean Myself off of the Trichlor tabs (because of the CYA and it lowering My PH) and using liquid bleach now. Found some 25 Mule Team Borax to bring up the PH from 7.2 to 7.4 Next Year, I'm ripping out the Hayward chlorinator (doesn't work with a 2 speed motor set on low anyway), and either use bleach every other Day or calcium Hypochlorite tabs in the skimmer and run the pump on low 24/7. My last Hayward Gold only lasted 3.5 years. I'm wondering if the chlorinator was constricting it too much. Anyway, I find the Hayward autochlorinator near worthless, anyway, and I was tired of getting gassed every time I took the lid off.
    Gary
    POOL SPECS: In-ground vinyl; 18 x 36' 24,000 Gallon,
