Depending on how you're testing, the high chlorine levels can be affecting your test. If you're trying to clean up an algae bloom, don't worry about the TA for now, you can always tweak that after the fact if you need to. Just worry about using an accurate CYA level to determine the bleach dose, and then getting the chlorine level up to the appropriate level and keeping it there until the algae is gone. Run the pump 24/7, clean the filter as your pressure indicates, and brush the pool daily.
