Thread: Easy Touch remote with Total Control?
    Aug 2011
    Default Easy Touch remote with Total Control?
    Just completed our in ground pool, and have the Pentair Pool Pilot system and the Total Control system. I splurged for the Easy Touch wireless remote and it's great for setting the pump system and lights, but I'm unable to get any readings on pH, chlorine, salt, etc from the Total Control. The Total Control manual says it supports remote systems, but I can't get it to work. I'm hoping it's just a setting, but I fear they are incompatible. Any ideas?
    Default Re: Easy Touch remote with Total Control?
    Hi and welcome! We have some people here who can probably help you. Once your registration is complete and your post is moved out into the SWCG section of the forum, they'll be able to see the post and should be able to give you some advice. Sit tight for now......
    just wanted to let you know you now have general forum access. -ben
  1. Dead heater, remote control, wiring jandy valves
    By jqgreen in forum Pool Equipment & Operations
    Last Post: 08-12-2012, 08:36 PM
  2. Replies: 1
    Last Post: 08-02-2012, 12:11 AM
  3. AutoPilot's Total Control System Help?
    By fjava in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-30-2007, 10:54 PM
  4. Autopilot Total Control??
    Last Post: 08-15-2006, 07:09 PM
  5. Remote control for pool heater/equipment
    By Dan6081 in forum In-Ground Pool Construction and Repair
    Last Post: 05-02-2006, 08:57 PM
