Results 1 to 10 of 10
Thread: high Chlorine usage
    Default Re: high Chlorine usage
    Pool Chlor, a service company that has run 10,000's of pools in Arizona since the 60's, sets up their customer pools with a CYA of 150 ppm, and then runs chlorine levels that approximate the ones in my Best Guess chart.
    You don't have to go that high, if you prefer not to do so, but 30 ppm CYA is too low for sunny AZ.
    My CYA is currently 90 ppm (intentionally) and I'm currently losing about 3 ppm of chlorine a day in approximately 29K gallon pool. Air temps 104-109, water temp today 97 degrees. There is a very obvious increase in chlorine consumption in my pool when the CYA gets any lower--I have a lot of splashout/replacement due to a high kid/dog bather load, and my chlorine consumption drastically increases when I get below 80 ppm CYA.
    Jul 2011
    Janet,
    At 90 ppm CYA how high do you keep your CHL? B.G.C. chart says 5 min 10 max 20 shock does that work for you?
    Anyone,
    Is there a easy formula to figure out exactly how much ppm I'm adding per ___ amount of chlorine to ___ gallon pool
    For your pool, each gallon of plain 6% household bleach will add about 4 ppm of chlorine. A pound of 62% available chlorine dichlor will add about 5 ppm. That's pretty simple.
    Ben
    Quote Originally Posted by oldkingcole View Post
    Janet,
    I keep mine at 8-9 ppm, at the higher end of the range, and my pool stays crystal clear year round.
    Jul 2011
    First off THANKS for the replies.
    I didn't get to test until 11am (3 ppm) now at 9pm CHL at 1 ppm. That's a lot better then it's been. Before raising the CYA to 55 I've tested in the afternoon and been +=5ppm and by 8pm it's -= .5 ppm. I'm going try 2 gallons tonight (8 ppm added to 1 = 9) and see how long she'll hold 5 or above. If I can hold += 5ppm for 24 hrs I can live with that. Just 1 1/2 to 3 gallons per day is a bit more then I bargained for.
    Jul 2011
    I tested the CYA this morning after dumping 4 lbs last night. I could still barely see some black at 60 but not at all at 50, so I think it fell somewhere in between. CHL looks dead on 3ppm (hth oto test). I'll see what kind of drop I get? Told wife & kids to stay out while I try to dial it in.
    After adding the cya I noticed a small decrease in PH? Is that normal? I'm assuming CYA PH is lower then the pool water which caused the drop is that accurate?
