Re: high Chlorine usage
My CYA is currently 90 ppm (intentionally) and I'm currently losing about 3 ppm of chlorine a day in approximately 29K gallon pool. Air temps 104-109, water temp today 97 degrees. There is a very obvious increase in chlorine consumption in my pool when the CYA gets any lower--I have a lot of splashout/replacement due to a high kid/dog bather load, and my chlorine consumption drastically increases when I get below 80 ppm CYA.
