Re: high Chlorine usage
First off THANKS for the replies.
I didn't get to test until 11am (3 ppm) now at 9pm CHL at 1 ppm. That's a lot better then it's been. Before raising the CYA to 55 I've tested in the afternoon and been +=5ppm and by 8pm it's -= .5 ppm. I'm going try 2 gallons tonight (8 ppm added to 1 = 9) and see how long she'll hold 5 or above. If I can hold += 5ppm for 24 hrs I can live with that. Just 1 1/2 to 3 gallons per day is a bit more then I bargained for.
