Thread: White water mold and pool floats
    Aug 2011
    York, PA
    Unhappy White water mold and pool floats
    It seems after using the floats, etc., white water mold begins to appear. Should I clean the floats first and how do I get rid of the water mold? I was told it's an animal type organism, but nothing seems to kill it short of backwashing the pool. Thank you.
    Default Re: White water mold and pool floats
    Chlorine kills it just fine, if you get the levels right.
    But, are you using Baquacil? If so the only way we support Baquacil (PHMB) pools is by helping people convert from them, to chlorine.
    Baquacil typically works well for a year or two, and then becomes a nightmare. You can avoid this by draining 2/3 of your pool every year, and by replacing your filter media (sand or cartridge) annually. If you haven't done that, and are using PHBM, there's no real fix.
  1. White Water Mold/ Pink Slime problem--- First steps....
    By weeznur32 in forum Dealing with Algae & Slime
    Last Post: 07-01-2013, 08:43 PM
  2. white mold
    By hockeymedic in forum Dealing with Algae & Slime
    Last Post: 05-17-2013, 06:48 PM
  3. How Do I Kill White Molds and Pink Slime?
    By smullins34 in forum Dealing with Algae & Slime
    Last Post: 06-15-2012, 01:52 PM
  4. Pink Algae and White Water Mold in Pool
    By pclstuff in forum Dealing with Algae & Slime
    Last Post: 06-07-2011, 05:26 PM
  5. White mold?
    By waste in forum Dealing with Algae & Slime
    Last Post: 06-28-2008, 08:33 PM
