Thread: Hello All need some advice.
    Aug 2011
    Upstate SC
    Default Hello All need some advice.
    Hello everyone,
    New to the forum and have been reading alot and rereading. Thanks for takeing the time to help everyone.
    I have an Intex style pool(Summer Escapes) 16' round. I belive 3700 gallons. Well needless to say that the so called pump that was shipped with it is useless. I purchased a sand filter and installed. 2650GPH. Between the time of getting the new filter the pool has green alge. After reading I purchased the Taylor K-2006 kit. After testing yesterday here are the readings.
    2.2 FC
    .6 CC
    High PH had to add 3 drops of R-0005 to get to 7.4 PH
    90 TA
    74 CYA
    I did put 1 gallon of bleach Saturday night, 1 gallon in Sunday, and 1 more on Monday. But because I did not have the Taylor kit yet I stopped. Could not tell what the FC was untill now.
    What should I do first?
    Thanks Kevin
    Default Re: Hello All need some advice.
    Hi Kevin;
    Sounds like you're on the right track. 1 gallon of plain 6% household bleach in your pool is a little more than 12 ppm chlorine. Given your high CYA level, you'll probably need to think more in terms of a 1.5 gallons per dose, with lower doses if you are able to hold your chlorine level. Use my Best Guess chart (linked in my sig) to determine the correct chlorine level, based on your CYA level.
    And, add some acid, to get your pH into the 7.2 - 7.8 range.
    Other than that, sounds like you've got the basic idea.
    Aug 2011
    Upstate SC
    Well there is a bottom in the pool. HaHa! Thanks to the help on this forum I can now see the bottom of my pool.
    Thanks again,
    Kevin
    Yay!! Keep up the good work, and enjoy the rest of your swim season!!
  1. need advice on what do to first
    By sherraechas in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-26-2012, 02:44 PM
  2. Hot tub advice
    By myatinsel in forum General Interest
    Last Post: 10-19-2011, 03:02 PM
  3. Need some advice
    By sherron100 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-10-2011, 08:33 PM
  4. 18' AG Advice
    By cramar in forum Above-Ground Pool Construction & Repair
    Last Post: 11-19-2010, 03:05 PM
  5. Advice please.
    By savdoc2 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-25-2006, 07:58 PM
