Results 1 to 10 of 13
Thread: plumbing question about a Pentair Intelliflo pump
    Default Re: plumbing question about a Pentair Intelliflo pump
    Can't answer that one -- I haven't compared prices and cost of installation.
    Any well sized multi-speed pump will save you a lot compared to a single speed run 24/7.
    It won't save as much money comparing a 2 speed run 2 hours on HI and 22 on LOW with a single speed run 6 hours on HI.
    HOWEVER, one of the big benefits of multi-speed pumps is that they are VERY quiet on low.
    Aug 2011
    It's 699.00 installed and they guarantee 750.00 savings "while under warranty" on a 1 HP replacement. The question is that the motor has a 2 year warranty and they are offering a free 3rd year so I'm not sure if the savings would be amortized over 2 or 3 years. They claim that they can put the electronics on my existing motor and show me the savings right then. If it's less than advertised then they deduct that amount from the purchase price.
    http://bayareapoolservice.com/
    Well, for starters I don't trust anyone who misrepresents a new law in order to scare consumers into making purchases. On the Bay Area Pool service site, they encourage you to 'beat' the new law's requirements.
    However, here's the law (from flsenate.gov):
    Current Situation
    The Florida Energy Efficiency Code, s. 553.909, F.S., provides minimum energy requirements for appliances. Residential pool pumps and pool pump motors with a total horsepower of 1HP or more must operate at a minimum of two speeds, with a low speed operating at half the rotation rate of the motor‟s maximum rate. The default circulation speed of residential pool pumps must be the residential filtration speed, with override capability for a higher speed for periods not to exceed 120 minutes. Solar pool heating systems are permitted to run at higher speeds during periods of usable solar heat gain.
    Proposed Changes (passed)
    The bill amends s. 553.909, F.S., to increase, from 120 minutes to 24 hours, the period that a residential pool pump motor‟s speed may be set higher than the default residential filtration speed.
    Now, if you read closely the only change is to make the requirements MORE permissive than they already were. So, whatever you *were* required to do, you are *now* given more leeway!
    And now, you can also see, whatever the Florida pool police are requiring, you are still good to go with a 2-speed motor!
    But, there's more than that. The "energy savings" are calculated against a 'standard induction motor' (read "least efficient motor we could find cataloged for pool use"), and NOT against YOUR pool or pump!
    Now, it looks like your dealer is in Tampa, Fl (Bay Area Pool Service (813) 889-9091 - 5015 W Waters Ave, Tampa, FL) so I assume you are, too. Based on this page [ http://www.tampaelectric.com/news/ra...sillustration/ ] it looks like your costs are about $0.10/KWH. A 1 HP motor draws about 0.7KW. So, if you run your pump 8 hours per day, 365 days per year, your total cost would be $292 per year.
    Now, according to this page [ http://www.a1poolparts.com/-strse-30...sh-/Detail.bok ], the warranty on that motor is two years. Bay Area Pool Service adds a 1 year warranty . . . I betcha it's got a bunch of fine print.
    So, in order to save you $750 during the warranty period of what you been spending, your total electrical costs would have to go from $876 (3 x $292) to $121 or $40.33 per year. That motor looks like a pretty good unit, but NOT that good.
    Plus, their energy calculator is all screwed up . . . 3 guesses who the errors favor (and the 1st 2 don't count!):
    1 speed, 6 hours:
    2 speed, 1 hr high, 23 hrs low:
    2 speed, 23 hrs high, 1 hr low:
    Bottom line:
    #1 - It's a brand new motor, with very good specs. But it's pricy . . . and it's brand new. When I was younger, "brand new" sounded great. Now, "brand new" in my mind equals "a chance to be part of the company's beta test team, AKA consumer guinea pigs". If it were me, I'd wait 2 years to buy a product like that. But, Marathon has been around for awhile, and this motor may be fine, especially if the tech has already been in use in industrial motors.
    #2 - As best I can tell, this motor will save you ALMOST nothing over a toggle switched 2-speed 3/4 HP motor. Run it on low 10 - 12 hours per day (2 periods) and on high when backwashing or vacuuming . . . and you'll save a bunch.
    #3 - Bay Area is playing fast and loose with the facts. They don't include installation costs -- and the "free" period has expired -- and they calculate savings against a mythical motor, not yours. My guess is, pay back will be over 5 years against your existing motor (if you use a timer) and NEVER against a standard 2-speed motor.
    #4 - But suit yourself. This motor costs more than a 2-speed, but not so much more that it will kill you. If you can afford to drop the $300 difference between a 2-speed motor, have at it. By the way, here are Internet prices for both types of motors:
    http://www.a1poolparts.com/-strse-12...eed/Detail.bok
    and
    Aug 2011
    Ben, thanks again for all of this information. BAP has extended the free installation past that shown on their site. However I can install this myself and will go that route if I use this motor.
    You have spent much time in giving me the facts to make an informed decision and I really appreciate it.
    My decision now will be between this motor and the 2 speed, both of which you provided links.
    Thanks again for your help.
    Hayward SuperPump comes in a 2 speed only at the 1HP or larger sizing. If they ever made a 3/4 version it must be over 10 years ago. My 1 HP SuperPump was purchased in 2002 and it was the smallest 2 speed Hayward made. Still going strong! Only thing I've replaced on it is the basket gasket. I don't think I'd buy a pump that's more than 10 years old.....
    I THINK Pentair may make a 3/4hp 2 speed. Someone does, but I've forgotten who.
    mas985's Avatar
    Pleasanton, CA
    The 1 HP uprated SuperPump (SP2607X102S) is actually a very small pump compared to many on the market today. It has a head curve that is lower than many smaller labeled pumps such as the full rated 1/2 HP Whisperflo. The Pentair SuperFlo full rated 3/4 HP pump (SF-N2-3/4A) is slightly smaller (lower head curve) than the SuperPump but has about the same efficeincy as the SuperPump. In fact, Pentair developed the SuperFlo series to compete directly with the SuperPump. Both the SuperPump and SuperFlo are great choices for pools with single 1 1/2" pipe runs.
    Mark
