Results 11 to 15 of 15
Thread: Searching for more about "Operating Swiming Pools at High PH"...
    Default Re: Searching for more about "Operating Swiming Pools at High PH"...
    You really don't need to worry much about either the TA or the CH on a small vinyl pool -- unless they are too high, it really doesn't matter. Don't put a lot of effort into 'adjusting' them.
    You do want to keep your pH somewhere between 7 and 8, but otherwise . . .
    Quote Originally Posted by Sponge1971 View Post
    That Muriatic Acid sure was intimidating. I diluted it in a 5gallon bucket of pool water, and slowly poured it into my skimmer.
    NOT a good idea, even when diluted. It is better to just pour it in the pool after you dilute it and then brush the pool to "mix" it. As an alternative you can pour it slowly into the stream of a return as long as the return is across the pool from the skimmer and not next to it.
    Jul 2011
    Bowmanville, Ontario, Canada
    Ooops. Ok for the reminder on proper acid addition...
    According to Ben's reply, I might not even have to worry about acid again...
    5300 Gallon (15' x 52" composite & aluminum - AG)
    (Not Salt Water - Liquid Chlorine - Trying BBB...)
    Sta-Rite Mod3 60sqft DE Filter (with 8lbs charge) - Sta-Rite 2" Dyna-Wave Pump (<<< L-O-V-E )
    All 2" plumbing (except 3" suction line, modified skimmer) - Two 1.5" returns at 180degrees apart (skimmer return piped down to floor)
    "15' round 5.1K gal AG pool; ~10% liquid Chlorine; Sta-Rite Mod3 60sqft DE Filter DE filter; Sta-Rite 2"" Dyna-Wave Pump pump; 11hrs; Taylor K-2006
    'drops' FAS-DPD Chlorine, ; utility water; summer: ; winter: ; iPhone; PF:24"
    Anyway, I put in about 1/2 of what the booklet recommended for a 5000gallon pool at 2 drops acid demand.
    From the Taylor booklet I have the half-amount (or 1 drop from the acid demand) in 5000 gallons is 4.6 fluid ounces of full-strength Muriatic Acid (31.45% Hydrochloric Acid). Diluting this amount in 5 gallons of water would have the pH go from -1 (yes, that's negative 1) of undiluted acid to +0.4 so still very acidic. Even pouring slowly into the skimmer doesn't help that much with the pH. Even if you poured at a slow 1 gallon per minute (about 1 cup every 4 seconds) with a skimmer flow rate of 20 GPM (so 1:20 dilution) the pH would still be +1.7 which is still low. pH is a logarithmic scale where every factor of 10 dilution of a strong acid or base solution is a 1 unit change in its pH.
    As waterbear noted, you really want to add the acid to the bulk pool water and mix it. As he noted, the safest way is to pour slowly in front of a return flow with the pump running and then to lightly brush the side and bottom of the pool in the area you added it to ensure thorough mixing. In fact, most pool products (acid, chlorine, etc.) are denser than water so if you add them too quickly in one place they can pool at the bottom. For some chemicals such as salt or borates, this might not be a big deal but for acid and chlorine it can. Once mixed, however, such chemicals remain mixed.
    By the way, it is this post on this forum where I first put up the chlorine/pH relationship with and without CYA.
    Jul 2011
    Thumbs up Re: Searching for more about "Operating Swiming Pools at High PH"...
    I just gotta say...You Guys...like...TOTALY ROCK!
  1. New to pools - is "root kill" (copper sulphate) good to use?
    By duffmama in forum Dealing with Algae & Slime
    Last Post: 05-28-2013, 10:53 AM
  2. Replies: 6
    Last Post: 04-25-2012, 05:12 PM
  3. Pool pH is at the "ideal" level, but alkalinity is super high
    By mindleak in forum Pool Chemistry for Intex-type Pools
    Last Post: 03-25-2012, 04:05 AM
  4. "Recipe" for SWCG pools??
    By Jodester in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-22-2010, 07:50 AM
  5. Have you see this "Montreal pools closed" ?
    By medvampire in forum General Interest
    Last Post: 08-22-2006, 12:38 AM
