PoolDoc
It's a function of time, filtration, and vacuuming.
You should think about clearing it AFTER you are pretty sure all the algae is dead. ALL the algae.
The key ingredient here is P.O.P. -- pool owner patience, or sometimes, pool owner persistence.
If you get impatient or in a hurry, and go buy some "floc" or other pool store chemicals, you can *sometimes* speed things up. But, there's some skill involved -- doing the right thing, the right way, at the right time -- and also some luck, because different 'blends' of muck react differently with various types of floc. Experienced pool service guys can usually be successful with this stuff, particularly when they've gotten used to working successfully with a particular product. But what happens, more often than now, when pool OWNERS use that stuff is that they make it worse, not better.
And, it's possible to make it MUCH worse. Many clarifiers actually work in reverse, suspending guck rather than sinking it, or making fine particles harder to filter rather than easier, if you misuse them.
